I swear I read through all 14 pages of clutch cable posts before asking this! My pedal (only had car few weeks) hangs lower than the brake or gas pedals. I did learn that my 1980 is NOT an auto adjuster from my reading! However, I fear that this is most likley a sign of the dreaded pedal fork failure? What I don't get is why the big pedal spring wouldn't still pull the pedal back to the full up position?
BTW, clutch works but you have to be very dilligent about FULLY depressing the pedal so adjsutment is probably also in order.
Clutch pedal sag
Clutch pedal sag
Jeff Klein, Aiken, SC
1989 Spider, sold
2008 Mercedes SL65
2008 S600 Mercedes V12
1989 Spider, sold
2008 Mercedes SL65
- perthling
- Your car is a: 1974 124 Spider
Re: Clutch pedal sag
If you adjust the nut at the gearbox end of the cable to tighten it you will most likely cure both ills - the additional pull from he cable when returning to engaged position will probably have the pedal at 'rest' past the 'sticking point' of the pedal return at present. At least, that's what mine did.
_______________________
Perthling
1975 Fiat 124 CC (project)
1969 Fiat 124AC (project)
http://www.fiatlancia.org.au
Perthling
- Your car is a: 1981 Spider Turbo - missing the turbo
Perthling,
Which way is tightening it , moving the nut forward or backwards along the thread ?
THE FLEET
2014 Abarth "SS"
2014 Abarth "SS"
forward or backward are relative to which way you look at things. reduce the amout of cable/stud between the fork and the pedal, or lengthen the stud length behind the fork.
that mighty spring does not do near as much "return" on that pedal as you think. some folks don't even bother replacing it once it comes off the pedal.
do you have a spring on the other end of the cable?
When my pedal failed, it wasn't like that. It was instantaneous and my foot and pedal slammed the firewall hard.
And the winners are perthling and mbouse! No spring at the tranny and out of adjustment!
Thanks to both for the advice.
1989 Spider, sold
2008 Mercedes SL65
1989 Spider, sold
2008 Mercedes SL65
super... it is always nice to find the solutions that cost little to impliment.
