Gas Tank Removal (Again)
RJ80
Your car is a: 1977 Lancia Scorpion
Post by RJ80 »
I'm planning to install my Abarth bumperettes this weekend and after reading various accounts on gas tank removal (to get to that rear bumper shock bolt on my '79) I've still got a couple questions. My tank is about 1/4 full according to my fuel gauge. Is that low enough to move the tank to the side without issue? And regarding moving (rather than REmoving) the tank, do I just loosen the mounting bolts and fuel filler hose to get it out of the way? Full removal isn't necessary, is it?
Thanks in advance for any words of wisdom.
pope
Re: Gas Tank Removal (Again)
Post by pope »
A 1/4 is about 4 gallons, because there is always a little more than the tank registers.
We are probably talking about 45 to 50lbs. here with tank. You be the judge.
mbouse
Post by mbouse »
six pound per gallon.
.25 x 11 x 6 = 16.50 pounds, plus the weight of the tank itself.
the filler hose goes into the bottom of the tank, when you remove it the remaining 4 gallons will escape and run away
azygoustoyou
Post by azygoustoyou »
You don't want to take a chance of it getting into your trunk. Do you?
kilrwail
Post by kilrwail »
azygoustoyou wrote:You don't want to take a chance of it getting into your trunk. Do you?
Don't worry - it will be all over the floor. ask me how I know :)
Peter Brownhill
1977 Porsche 911S - track car
2022 Ram 4 x 4 - hauler
mbouse
Post by mbouse »
well, that will save mopping up the trunk, 'eh? gasoline on the concrete floor will evaporate!
baltobernie
Post by baltobernie »
The large diameter filler hose Mark refers to is a real bear to install, even when new and flexible. You might want to order one beforehand, because the one on your car will probably be ruined by the time you get it off.
With the tank out, here's your opportunity to clean out all the sediment and rust that has accumulated over the years. Examine the fuel pickup filter, which keeps crud out of the fuel pump. It's a mesh "sock" which often deteriorates over time. And be gentle with hose fittings attached to plastic nipples on emissions and fuel system components. Leave them intact whenever you can.
When I removed and reconditioned my tank, I'm sorry I didn't weld in a bung to enable draining the tank for the off-season. You probably won't need one in SoCal, though.
RJ80
Post by RJ80 »
Bah, looks like I'm not going to be able to take the easy way out on this one then. Thanks for the responses guys, guess I'll be searching for a local shop to clean and coat the tank while it's out.
Rory
azygoustoyou
I just did that to my tank. It was a pain but I've done worst. It's possible to do that job yourself for about $45.00. The worst part of the whole thing was doing the last step. Getting the coating everywhere in the tank was easy. Trying to get the left over out wasn't. Your not suppose to let it puddle inside, so you have to just keep turning it.
launieg
Post by launieg »
Yeah, that was my experience too (getting all the coating out). I sure wish I'd installed a drain cock (hee hee) too! My son's BMW has one, and it is easy to drain the tank and put in fresh gas, etc. Take this as a strong recommendation!
Launie
