Jack Tie Down
courtenay
Jack Tie Down
Post by courtenay »
Can someone take a picture of what the jack is supposed to look like when tied down in the trunk? Mine is loose - and while surrounded by padding still rattles and bangs whenever I go over any bumps in the road.
Bruce Shearer
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
Online
kilrwail
Re: Jack Tie Down
Post by kilrwail »
Here you go. The exposed bolt end of the jack is towards the front of the car, inserted in the round hole up on the fender. This tool kit is not the original, but it's the same size. (The original is stored except for shows.) You need a rubber strap with rectangular rings on each end, to go around the tool box and the jack, holding them both secure.
Peter Brownhill
1977 Porsche 911S - track car
2022 Ram 4 x 4 - hauler
narfire
Re: Jack Tie Down
Post by narfire »
Make sure you have that jack strapped in there. I did'nt have a proper fitting one and the jack must have come loose,cause a couple of hard left turns the end of the jack slamed into the inside of the fender and I now have a couple of "outie" dimples on the fender. Getting quotes on the fix the next couple of days.
courtenay
Re: Jack Tie Down
Post by courtenay »
Aha - I'm missing the little rubber strap!! Is the tool kit a Fiat item? Don't have one of those either. What's in it?
Bruce Shearer
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
Online
kilrwail
Re: Jack Tie Down
Post by kilrwail »
You can read all about the tool kit here:
http://www.fiatspider.com/f08/viewtopic ... kit#p61912
If you don't have one, you'll need a much shorter rubber strap.
Peter Brownhill
ventura ace
Re: Jack Tie Down
Post by ventura ace »
My jack is stored a little differently (1970 spider):
The tool kit is strapped on the opposite wheel well:
Since your car is a later model, I would guess that the jack may be stored similar to Peter's, but I thought you might want to see an alternate solution,
A
courtenay
Re: Jack Tie Down
Post by courtenay »
Thanks, all. In looking at the pictures, I realize that not only do I not have a tool kit, I don't have a tire iron as well. Going to be tough to get those wheel nuts off without one. I think I will have to make my own little kit up and strap it in nice and tight!!
Bruce Shearer
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
adrians
Your car is a: 1981 Spider Turbo - missing the turbo
Re: Jack Tie Down
Post by adrians »
There is always Fiat tool kits for sale on Ebay .... keep an eye out !
THE FLEET
2014 Abarth "SS"
Online
kilrwail
Re: Jack Tie Down
Post by kilrwail »
Unless you're an 800 lb gorilla, you'll want a longer wheel bolt wrench than the one in the standard tool kit - it's only about 8" long! I keep mine with the spare tire.
Peter Brownhill
courtenay
Re: Jack Tie Down
Post by courtenay »
Thanks, Peter. As I'm only a 260 lb gorilla, I will make sure I get a long wrench.
Bruce Shearer
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
SpiderJim
Re: Jack Tie Down
Post by SpiderJim »
You should ask the SOB who sold you the car why he did not include the tie strap and toolkit..... Laugh
boogiedude
Re: Jack Tie Down
Post by boogiedude »
Who needs a longer tire iron? I'm a 160lb chimp and I have no problem breaking loose wheel bolts with my handy dandy stock fiat tire iron. If you can't pull it, jump on it! :lol:
