more guessing games
Re: more guessing games
Melted dist cap. Acid or heat?
- ga.spyder
That thing must have a really hot coil !
Craig Nelson
Fling It Around Turns !
- wachuko
- Contact:
Melted distributor cover... caused by a bad CDI box or coil?
Drive Safe!
Wachuko
1967 912 Progress Thread
2012 BMW X5 xDrive35d
2015 FIAT Abarth
Wachuko
2015 FIAT Abarth
Definitely a distributor cap. But what caused it? Did a tube from the heat riser fall on it?
Ron
Ron
good guesses, except for the stab at poor ol' Toyota. It's definitely a dist cap from an electronic distributor running a high output coil (about 40k volts max). The coil wire slipped out while the owner was driving, and the spark was strong enough to keep jumping the cap. The arcing kept eating away the contacts until the cap caught on fire. Once the fire melted the cap down onto the rotor the engine quit. It appears the spark was jumping about 2 inches at the end of the event. The owner reported he noticed just a slight hesitation when accelerating before the car died. Luckily, no other damage other then the cap, rotor and coil wire
Aww I did not get a chance to guess
Of course my guess would have been either0" It was Profesor Plum in the Kitchen with a Rope" or something to do with bigfoot.
