Extreme Makeover: Free-iat Edition
Re: Extreme Makeover: Free-iat Edition
See that is typical of me. When I rush I end up doing things twice. Sorry about the double post. Enjoy the day
4babycar
Post by 4babycar »
Thanks for the advice on the fuel pump. Part of the checks we performed was to verify that the fuel pump works and it was able to shoot fuel from a small cup half way across the room so I think it is working quite well. I also have a spare if needed.
4babycar
Post by 4babycar »
Its ALIVE! Spent most of the day removing the injectors and all associated parts and hose and cleaning them. Once everything was installed, it ran on the first time! I seem to either have an exhaust leak or a fluid leak onto the lower manifold so I have to work on that and the throttle body heater still didn't seal so I have to work on that again. Overall I am happy with the day's work.
launieg
Post by launieg »
Great, great! Well done. You feel good and we all do too :lol:
It goes to prove (again) that simply working one's way through the system, cleaning, fixing, and making sure everything is in good shape is often the fastest solution to a mindbending problem. Forget the problem (symptom) and focus on establishin a solid system and the problem goes away. (Okay, sorry for the lecture - just a reminder to myself. :roll:)
Launie
wachuko
Your car is a: 1981 Fiat 2000 Spider
Contact:
Post by wachuko »
launieg wrote:Great, great! Well done. You feel good and we all do too :lol:
It goes to prove (again) that simply working one's way through the system, cleaning, fixing, and making sure everything is in good shape is often the fastest solution to a mind-bending problem. Forget the problem (symptom) and focus on establishing a solid system and the problem goes away. (Okay, sorry for the lecture - just a reminder to myself. :roll:)
+1, so true. and, lecture away, we can always be reminded of something we knew or learn something new. Image
4babycar, congratulations in bringing it back from the dead, way to go!!
Drive Safe!
Wachuko
1967 912 Progress Thread
2012 BMW X5 xDrive35d
2015 FIAT Abarth
rlux4
Post by rlux4 »
Congratulations Michael! That's great news.
Ron
Ron Luxmore
rlux2n2@gmail.com
ga.spyder
Post by ga.spyder »
Way to go Michael.Its well on its way to FFO! :D
Craig
Craig Nelson
Fling It Around Turns !
4babycar
Post by 4babycar »
YES! I hope for this year to be my first FFO and hopefully will arrive (and return whilst driving) in my new car too!
ga.spyder
Post by ga.spyder »
Michael,if you plan on going shoot me a pm or a emaiL.I have the contact for the room coordinator and she can guarantee you a ground floor room,facing the pool.Our Friday luau,the drive-in movie and the banquet hall are all in this area.We are also going to keep our cars parked in this same field.You will literally have your car parked right outside the glass doors to your room.Anyone who has a reservation,I will give you this contact.I hope your family can make it,Michael!
Craig
Craig Nelson
4babycar
Post by 4babycar »
This weekend, with the help of the Blue Ridge Chapter of FLU and a few additional kind folks, the free-iat has a new timing belt and tensioner bearing. We had a great work session with about 12 Italian car lovers in attendance and one dog. I only managed to break one bolt off, on the coolant T, otherwise everything went pretty smoothly.
Unfortunately, the good feelings didn't last long. After putting the radiator back in and filling the coolant system, I ran the car for a few minutes to burp the system and there was a small pop, a hiss, the car started running poorly and substantial puddle of oil gathering under the car. I quickly turned it off and began investigating. The head gasket had failed at the passenger side corner, near cylinder #1 on the passenger side. So, I guess I get to re-do the timing belt as well as replace the head gasket. I am now trying to decide if, for expedience I should shop out the gasket and concentrate on getting in done quickly and have some road time before FFO or if I should take the plunge and teach myself to change the gasket myself.
