So Cal Mark wrote:960 should only occur under a pretty heavy load. If that was at idle I'd look at the fuel mixture and timing very closely. Both of those items will have an effect on exhaust temps. If the car is running a cat. I'd check the temp at the inlet and outlet and see if it's restricted. When you get over 1000F, mild steel won't hold up very well depending on the gauge of course
Mark, thank you. That was measured not at idle but at high revs. I will measure, just for fun, temps around the cat and post them here.
The whole system will be replaced by your system (trying to sneak out the credit card without my wife knowing
). Which reminds me that I have to add a wish list in my other thread.
Also, at your suggestion, I will get rid of the air box. The one in this car was deformed, I am thinking because of the extreme heat...
I don't want to hide the new headers under a mess of heatshields... there has to be some better way to protect these parts and still have complete visibility of the headers...
