oil pump pulley position?
I am finishing the replacement of the timing belt, tensioner, water pump, et. I wondered if the oil pump pulley has to be positioned (turned) in a particular position based on a mark on the pulley. If so, why is that? There is a reference in the shop manual I have to position it at 32 degrees if I remember. Sorry if this is a odd or dumb question. The Fiat continues to be a great "educational" tool.
Re: oil pump pulley position?
the aux shaft position is important due to the fuel pump lobe. I align the pulley mark with the tensioner pivot bolt, approx 1 o'clock
Thanks Mark. What would be the result of it not being in the right position?
It will hit the crank and put a nice hole in the block. If ever the block is apart , you can cut the lobe off the shaft and set that pully anywhere,
- wachuko
- Contact:
Here, let me show you: http://www.fiatspider.com/f08/viewtopic.php?f=5&t=8938deacon wrote:Thanks Mark. What would be the result of it not being in the right position?
Aux shaft end
This engine block is toast? or can that be welded?
Drive Safe!
Wachuko
1967 912 Progress Thread
2012 BMW X5 xDrive35d
2015 FIAT Abarth
Wachuko
2015 FIAT Abarth
- wachuko
- Contact:
And that is just the block. I was told that the connecting rod that hits the aux shaft could also suffer damage. I have not check mine closely ... will do so in the next few days as I start working on it again.deacon wrote:Ouch.....
Drive Safe!
Wachuko
2015 FIAT Abarth
Wachuko
2015 FIAT Abarth
