Water Tee gasket -- glue required??
Tango
Post by Tango »
When putting my cooling system back together, I have a new gasket for the water tee / union. Are these normally applied dry or with some kind of sealant? The PO's mechanic re-installed it (upside down) as far as I can see with no gasket at all, just a red rubbery sealant.
Tim
bajacalal
Re: Water Tee gasket -- glue required??
Post by bajacalal »
I use a product called Hylomar Universal Blue for this sort of thing, it's a viscous blue, non-hardening liquid, Amazon.com has it. It's kind of hard to find, I guess it was developed by Rolls-Royce or something. I think it does a very good job at sealing things that aren't perfectly smooth anymore.
I also used a carburetor mounting gasket for early aircooled VWs with a single barrel carb for my water tee. It fit just fine, sealed fine and could be found locally for about a dollar.
SLOSpider
Post by SLOSpider »
You want some kind of sealant on there, RTV, or the liquid brush on kind just about anything is ok. If you use RTV just use a very THIN coast as not to get goobs of extra in your radiator and cooling system.
1975 124 Spider
1989 Chevy k5 Blazer
1967 GT Mustang Fastback
katsi
Post by katsi »
I used a thin layer of of that red hi-temp sylicone gasket stuff. I buy it at the 99 cent store. They have red, black and blue. I also used it to seal up the metal patches in my floor boards so no water will get in. Works great and it's really in-expensive. :mrgreen:
Tango
Post by Tango »
I'll see if I can get some RTV type material on the way home tonight. I want to get it running so I can take it to work on Thursday. Supposed to be a gorgeous day and Friday is a holiday up here in the Great White North. 8)
T
Online
kilrwail
Post by kilrwail »
Tim - CTC has RTV sealant - I think it's Permatex and it's fine.
Peter Brownhill
1977 Porsche 911S - track car
2022 Ram 4 x 4 - hauler
