Penzoil Synchromesh Transmission oil?
dantye
Your car is a: all gone
Post by dantye »
Many Parts stores carry this non-GL5 oil, specified for a few GM and Chrysler models with brass, bronze and/or copper parts.
I understand that such parts are the reason you should not use GL-5 in a spider transmission.
Anyone have experience using this oil in a Spider?
Thanks!
kilrwail
Re: Penzoil Synchromesh Transmission oil?
Post by kilrwail »
Yes, it will be fine. A little pricey compared to NAPA GL-1 non-EP, but fine.
Peter Brownhill
1977 Porsche 911S - track car
2022 Ram 4 x 4 - hauler
dantye
Post by dantye »
kilrwail wrote:Yes, it will be fine. A little pricey compared to NAPA GL-1 non-EP, but fine.
Thanks - you are right, but our Napa store closed after both O'Reilley and Advanced A.P. moved into our little town.
Could not find other GL-1, Non-EP here, and shipping would make it a wash @ $7.49/qt.
My concern was that NO GL or EP rating of any kind appears on the product container - Just the GM and Chrysler spec numbers.
Thanks again - maybe your post will also help someone else in the same spot.
mdrburchette
Post by mdrburchette »
I believe Synchromesh is also a synthetic and maybe why it's labeled differently.
1972 124 Spider (Don)
1971 124 Spider (Juan)
1986 Bertone X19 (Blue)
1978 124 Spider Lemons racer
1974 X19 SCCA racer (Paul)
dantye
Post by dantye »
mdrburchette wrote:I believe Synchromesh is also a synthetic and maybe why it's labeled differently.
Spec sheet I found cautions against ANY "off-spec." use, so I will take it back for a refund and get a "known."
Better safe than sorry.
Pennzoil Spec sheet: http://www.pennzoil.com/documents/Synch ... 0Fluid.pdf
kilrwail
Post by kilrwail »
Peter Brownhill
dantye
Post by dantye »
After some more research, not only are you correct, but the more modern "synchromesh" oil seems to be considered superior to GL-1 by many. There is an extensive thread on the topic on another board:
[url] http://xwebforums.org/archive/index.php?t-502.html/url]
Thanks!
TulsaSpider
Post by TulsaSpider »
I contacted Pennzoil. They did not recommend it for our transmissions.
