Timing belt tensioner
How much movement should I expect when I try to untension the timing belt tensioner to install the new belt? The water pump seems to be in the way of any significant movement and when I loosen the pivot bolt the tensioner still doesn't seem to move , even a little bit, even when I try to pry it with a screwdriver. Should I have to stretch to get the belt over the cam gears? It's a new belt and new tensioner.
- SLOSpider
Re: Timing belt tensioner
There are 2 bolts that I loosen, one that the spring mounts on too, and the nut on the bearing, as pointed out by Mark, then should move about 1/2 an inch, not much. Once you get it moved you can tighten down the inner bolt to hold it there.
1975 124 Spider
1989 Chevy k5 Blazer
1967 GT Mustang Fastback
IIRC, on my 81, which I just did (I and I am a novice here) the tensioner idler only had room to be forced back about less than 1/4". But the timing belt didnt have to be "stretched" over anything. It was just satisfyingly snug, it needs to fit around everything size-for-size and it does so. Also, that is a very strong spring and forcing back the tensioner was not that easy (not that simple to find a good leverage point from what I found).
No matter what I pry on this thing with it does not move, in either direction! I'd like to take the bracket off but I don't know how hard it is to put back with that big spring! I tried prying it with a 4 foot crow bar but no luck. I'm stumped.
- SLOSpider
It may be rusted onto the block then. I would go ahead and take the whole thing off. Once you get it off and cleaned up its not hard to put it back on. If your putting on a new belt you can just cut off your old one.
Um yeah what Mark said V, you did loosen he nut on the bearing itself?
1975 124 Spider
besides the pivot bolt, you must loosen the 17mm nut in the middle of the bearing
- wachuko
- Contact:
Practice removing and installing the spring in its place... a pita at first and after a few tries you get the hand of it... it is a combination of Zen, Yoga, and Ultimate Fighting....
Drive Safe!
Wachuko
1967 912 Progress Thread
2012 BMW X5 xDrive35d
2015 FIAT Abarth
Wachuko
2015 FIAT Abarth
