Coolant
mbouse
Post by mbouse »
Manifold vacuum is where you hooked your brake booster to (directly on the manifold).
Ported vacuum is where you hooked your dizzy to (at the carb). the pull will be much less here.
tonysfiat
Post by tonysfiat »
Mike
thanks
that is where i connected the tranny vacuum modulator tube
manifold vacuum is below the throttle plate, thus drawn from the manifold. Ported vacuum is above the throttle plate, thus is not present at idle or when the throttle is closed
mbouse
Post by mbouse »
much better defined than my answer. thanks mark.
manoa matt
FIAT AUTO TRANS PROBLEMS
Post by manoa matt »
hey guys
Does anyone know if the Fiat Automatic Transmission uses electrical shift solenoids? Or are solenoids only for more recent cars? I'm not familiar with the design of older model autotransmissions. However I got a 98 Jeep Cherokee, I started to loose shifiting between 1 and 2 I experienced some slipping and jerking. I changed the shift solenoids and problem solved.
matt
the Fiat auto is a GM TH180 and does not use electrical solenoids to control shifting (a blessing IMHO)
