Now I use a weber 34 ADF, I also have a set of 2x40 IDF.I am now kissing you on the cheek, and hope you have heeded my advice about other modifications necessary to run this carb in a street application.
I like the best 34 ADF, it seems as if it provides the same power as the IDF's up to about 5000 rpm, and it's in this area runs most of the time.
Sometimes I miss a little bit more in the top, can a weber 38 give me that?
Engine:
2 Liter
Cam - 285V-street performance, power range 2800-6800, Slightly lumpy idle. Spec-285 duration, 385 lift
Exhaust system is a 2 1 / 4 "high flow system
What will be the best carburetor for this setup?
