Here is the problem: the brakes will work great for a while with no pull to either side and nice even strong stops. THEN, over a very short time / miles the pedal will start to go mushy and the car will begin to pull to one side or another. I pull all the wheels and re-bleed and lo and behold I have a lot of air in the rear brakes (mostly driver side but in both). Yes I have the compensator rod such that it isn't closing off the circuit and I re-bleed until I have solid fluid and put it all back together. Works great for a while and then, repeat!
![Evil or Very Mad :evil:](./images/smilies/icon_evil.gif)
BTW, no apparent loss of fluid anywhere between good and bad? Is air entering the system of do I just have to keep doing this over and over until I REALLY get all the air out? I think counting the initial bleed I am up to three or four cycles.
Also, I know a couple of options exist for upgrading the front brakes but is there any rear brake option? I now have 15" Rotas so I can fit bigger rotors.
