I did some adjustments and my car ended up with a very heavy steering
![Sad :(](./images/smilies/icon_sad.gif)
Right now i 've 3/4 negative camber ,4 deg positive caster.
Do you think that i have overdone it with these angles ?
Do you think that the steering wheel is to small that it makes the steering heavier only by it self? A st wheel with 1 inch or more diameter might change the effort dramaticaly ?
What tyre pressures are the proper ones to improve the situation or what other adjustments should i perform to make steering lighter.
