The latest in updates - small bits of progress here and there. Front steering gear in, front suspension now all complete, and now dropping the transaxle out again to fit the brake compensator and get the rear brake line all good to go so that I can get the remaining brake lines installed.
I've painted the top of the fuel filler silver - not sure that I like it though, it's almost too shiny. Maybe I should have stuck to black - does anyone have a photo of the top of their fuel filler tube taken from through the flap they could show me? I've also been working out the wiring of the trunk light and trying work out where it is supposed to run. I don't think it was working in the car before I disassembled it for painting so am making up the connection to the jam switch near the trunk hinges (which I've replaced) but now I'm not sure where the wiring should go - I can see how the yellow/black wires are held by the clips on the rear of the back seat wall at the top, but not sure how they make their way around the hinge itself after leaving the main loom. At the moment they're travelling in front of the hinge because I can't see a hole behind. I'm contemplating drilling a hole in the plate that holds the hinge - does anyone have a photo of that area to see how other cars loo?
Have finished disassembling, cleaning and painting the propshaft with POR-15 and chassis black on top. Now to reassemble with new universal joints and bearings...
And lastly, I bought myself a nickel plating kit - I'm trying plating for a few small pieces. Will let you know how that goes....
(cleaned and ready to plate)
(the setup - I knew the sous vide would come in useful for something!)
![Image](http://i241.photobucket.com/albums/ff145/Lancista42/Fiat%20spider/Jan%202014%20onwards/IMG_2490_zpsiahzxbii.jpg)
