good ole boy shop local had bought out a dealership long long ago and had "bunch o parts... come on down and take a look"
well i found this
looks to be the same size inlets holes as the old one... same configuration .... and it started opening at about 181 and by 186 was fully open in the hot water test.... and it was only 20 bucks
couple of questions
after filling everything as in the manual it says allow to run thru 2 fan cycles.... now when this is happeninng at any point do i take off the radiator cap and look or what... how do i know that the water is movving as it should
next question..... is this the correct location for my temp sensor
