fiatfactory wrote:
With these you would be likely changing pistons to increase the static CR, and would require conversion to N/S style sumps... plus a few other minor things.
SteveC
minor things?
intake and exhaust are on different sides of the engine, the manifold is pointing in the wrong direction, the throttle body is in the firewall, even though its on the wrong side. totally custom header needed or turbo system and a head pipe
cooling system designed for fwd, all that stuff hanging off the back of the engine and firewall will clash, (more modification)
as you said, sump and oil pump, and i am sure there is more, this was at a quick glance.
designed for turbocharging, so pistons or a turbocharger
plus 2811.00 price tag and shipping from germany, then add all the modifications. speed is truly expenive
my thoughts is you would have well over 8,000.00 in this engine to get how many hp?
not arguing, just thinking out loud
