ralphcap wrote:Y'all are great detectives. Here's my confession. The damage to the crossmember was the result of two events or maybe both. First, several months ago my drive shaft separated from the differential and I had to drive about a block before I could pull over. I had it towed home and after inspection (by a novice, me) I just bolted it back up and away I drove. Second, as Matt diagnosed, I've been jacking the front end up using the transmission mount crossmember! There, I feel a lot better! Now, am I missing some sort of a bridge?
Well, maybe I used the wrong choice of words and made a mistake. I thought I was looking at the third bracket...
Pardon the rust, here is a photo of the area:
Your transmission mount bracket (1) needs to be replaced. The second bracket (2). The one upside down, needs to be installed correctly. There is a third one (3) that has the drive shaft support (the one that holds a big bearing).
