Page 12 of 13
Re: 1979 spider 2000 restoration
Posted: Sat Sep 20, 2014 9:25 pm
by fredguaz
Keep up the good work, JD.
I hope you know that you are an inspiration to those of us out here who think WE have issues with our cars!
Now when I run into a major issue, I just ask myself, "What would JD do?"
Posted: Sun Sep 21, 2014 7:41 am
by SoFlaFiat
That work crap really gets in the way doesn't it?
Posted: Mon Nov 17, 2014 11:26 pm
by MrJD
Look out, someone got back on the wagon tonight...
pounded flat after cutting off the car
replacement cut and shaped
fit isn't bad
Also got my radio in and installed in the dash and cleaned up my kick panels. Going to order new speakers to put in them soon. Need to find some chrome trim for the map pockets...
I wonder what these oversized valves are for? I ordered them from mark on Friday, they got here today which is a monday. Tomorrow they got in to the hands of my machinist. Gotta love good service, thanks Mark.
Posted: Wed Nov 19, 2014 10:29 am
by steve8462
how do the hinge plates look inside your doors. i have to try to find a way to re-build mine in the drivers door. i would love to see pictures of how you do it, if you have to.
Posted: Wed Nov 19, 2014 2:07 pm
by MrJD
Are you talking about the area where the door hinge bolts up to the car frame/body?
One of mine is cracked unfortunately... I've not fixed it yet, but I plan on getting a thick peice of cold rolled still and making a bit of a "washer" out of it and bolting it between the cracked mount and the door hinge. This would give it enough support, and the door should be adjustable enough to compensate for the thickness.
If that is what you are talking about, I will take a picture and show you what I mean.
Jon
Posted: Thu Nov 20, 2014 4:54 pm
by steve8462
i'm actually talking about in the door itself behind the door cards. it seems to be a chronic weak point for these cars
Posted: Thu Nov 20, 2014 5:19 pm
by MrJD
funny reading my spelling errors, lol. Cold rolled steel*
So is yours cracked? Snap a picture and show me what you are dealing with.
Posted: Mon Dec 29, 2014 4:58 am
by MrJD
will update things done soon.
Question:
I have new reservoirs, a new head, new alternator, starter, waterpump/timing belt kit, new radiator and fan switch (need to order an electric fan), new carb, new manifold, and a full gasket set.
Should i upgrade anything in the ignition? i don't want a new ignition system, but should I mess with the 79 electronic ignition at all? I know i will get a new hot coil, but anything else?
Should I install new freeze plugs when I have it all torn down?
Also, anyone got a single intake stud laying around they can send me?
Ahem.
My plan: I want to start the car again with everything stock, I assume I can run the car on an "IV" of gas since I don't have the tank or lines in it. Once I know it runs, I am going to put the upgraded carb on the stock manifold and start it again. I just want to make sure the carb works!
Once that is done I will pull everything out, and replace it all. Might leave it out till the car goes in for paint... just to do the engine bay.
Posted: Mon Dec 29, 2014 7:06 am
by vandor
The stock electronic ignition is not bad, just make sure all the components are in good working order.
Posted: Mon Dec 29, 2014 12:57 pm
by MrJD
did you get my facebook message? I went ahead and ordered a rear passenger side fender lip repair panel from you guys, but wanted some detail about the rear upper replacement panel.
Posted: Wed Dec 31, 2014 4:38 pm
by 124JOE
One intake stud.yes pm me your address
Posted: Mon Aug 10, 2015 7:56 pm
by 707kevin
I just read every page only to find that there is no news since last December
Looks like it was going so well, how is it now??
I'm about to cut the RH floor out, then take care of the rear valance rust. Rockers will come off tonight, hopefully not bad!
Posted: Tue Aug 11, 2015 9:50 am
by joelittel
707kevin wrote:I just read every page only to find that there is no news since last December
I did the same and would love to know how the car turned out. Any pictures you can share?
Posted: Tue Aug 18, 2015 8:51 pm
by 707kevin
I did the same and would love to know how the car turned out. Any pictures you can share?[/quote]
Right? What else an I supposed to do at work?
Posted: Wed Sep 16, 2015 12:29 pm
by MrJD
I took a little break for the last few months. I have worked on it though. I don't know what to do about the rear panel on the car. I hate to put filler over rust holes, but I am getting to that point. IF I use filler on the rear panel to cover some holes, then all I have to do is weld in a new structural member on the right side, and install the right rear inner fender and the body work will be done.
Sometimes, you just have to take a step back.
And I still need an intake stud, and also some nuts and bolts. Anyone have a warped head laying around they can strip a fastner or two off of?
I'll post pictures of my epic 1 year only head later.
