Had alternator rebuilt & put in new battery but something keeps killng the battery. When I put the cables on the battery, there is a spark even though everything is turned off. HELP!
Had this happen to me. Hook up a volt meter between the neg battery post and the negative cable, Take a look at the voltage reading. Now remove one fuse at a time until the voltage reading changes. Consult your owner manual which specify which fuse is for what. This will help you find the faulty circuit.
