Speedo Cable?? (SOLVED)
Posted: Wed Jul 14, 2010 11:18 am
The PO of my 1976 appears at some point to have replaced the dash with one from a Spider 2000, or so it says on the glove box. I have the deep well guages both speedo and tach and the speedo was not hooked up or functional. On the back of the speedo the cable attaches with a plastic clip built into the cable as you might expect.
There is a device under the dash which the cable from the transmission is plugged into, looks like a junction box with a place to connect an upper cable?? It has a threaded input/output on each side and is bolted in place. There are two wires coming from this thing which I have not bothered to trace as yet.
My question:
Is this a common configuration and does anyone know what I should be asking for in order to get someone to sell me this part so I can see how fast I am flying down the highway again?
My question:
