car just dies
jake1234
car just dies
Post by jake1234 »
hello, i'm new to the forum just discovered it a few days ago, seems like a cool place. Anyways i have a 1977 124 spider the car idel's fine and sounds good,but as soon as i try to rev the engine it dies. I thought it might be the fuel pump, but i installed a new one along with a new filter and i still have the same problem. I'm thinking it's the accelarator pump on the carb but i'm not sure any insight would be greatly appretiated. Thanks
NJFIAT1981
Your car is a: 1970 SPIDER AND A 1976 SPIDER
Re: car just dies
Post by NJFIAT1981 »
Hi Jake,
Welcome to the fourm. Where are you located? I have FI Spiders but I'm sure you will have several suggestions by tomorrow. How about some pics of your Spider. Good luck, George
Re: car just dies
worn accelerator pumps are common and easy to replace. The o-ring on the discharge nozzle could be worn also, preventing all of the fuel from entering the venturi.
