Chassis Lubrication
- courtenay
Chassis Lubrication
I can't find any references in my various Fiat manuals about chassis lubrication. I also don't see very many lube nipples under the car. Am I missing something??
Bruce Shearer
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
Re: Chassis Lubrication
Nope... I found just the one on the sliding fitting on the driveshaft just behind the flex disk
some brands of ball joints have zerk fittings, and some u-joints. A small dab of grease on the steering stops is a good idea too
Hey!
I also found 2 lube nipples on the driveshaft, one in front and one at the end . But there is no way I can use a lubepress there, there is to little room to get acces. Whats the trick ?
regards
FMO
regards
FMO
Without crawling under my spider and looking..... and this first suggestion may sound stupid, but worth metioning... can you turn the driveshaft to gain access??
Also, they make a variety of adapters to fit grease guns, so you can get to almost anything. here in the shop I have a bunch of them.
Keith
Keith
