Page 1 of 1
Interior Back from Upholstery Shop
Posted: Wed Jan 26, 2011 10:41 pm
by unplugged
I went a bit darker than original tan interior which can be seen on the 2 door panels next to it.
For the center console I had them duplicate the stitched look from the Anniversary Edition model.
I am pumped to install it once it warms up a tad.
Dave
Re: Interior Back from Upholstery Shop
Posted: Wed Jan 26, 2011 11:25 pm
by So Cal Mark
it looks great!
Posted: Thu Jan 27, 2011 12:09 am
by divace73
Nice work, how much does something like that set you back in the US?
Posted: Thu Jan 27, 2011 4:53 am
by Zippy
Looks great! I especially like the stitched console. It's going to make your car look like it was custom made. Have you decided what you are going to do with the door panels?
Posted: Thu Jan 27, 2011 12:01 pm
by unplugged
I had the entire interior redone in the same color.
Front Seats, Rear Seats, Rear Qtr Panels, Door panels, Ctr Console, and matching boot.
The front seats had the foam redone and firmed up, the rear seats had rust that had to be stripped and coated and some padding redone.
The cost was around $3,500.
Posted: Thu Jan 27, 2011 4:10 pm
by divace73
Hi Unplugged
Did you also have to repair your seat frames? Mine are buggered....
I am expecting around the AUD$4k mark as well.
Posted: Thu Jan 27, 2011 8:08 pm
by Fiat88
They did nice work! Like the color.
Posted: Thu Jan 27, 2011 10:54 pm
by unplugged
Fortunately the seat frames were in good shape.
Posted: Fri Jan 28, 2011 2:37 am
by grittracing
that looks great I like the stitching on the center console did you do the radio console the same?
Posted: Fri Jan 28, 2011 10:39 am
by baltobernie
Going to be a great looking car! What color exterior? Are you re-doing the dash, too?
Posted: Fri Jan 28, 2011 3:51 pm
by unplugged
Upper Console matches lower console.
Exterior is Blue
The seat in the picture is the original color.
I am planning on redoing the dash in Bird's Eye Maple. Inspired by Denise's dash. Engineered wood flooring from Home Depot makes a good base. Cuts clean and is stiffer then plywood. I used contact cement for my first attempt and it did not work out too well. I bought the veneer 6+ years ago so it was very dry and not very flat. The contact cement setup too fast to allow me to press it flat. Live and learn.
Album of restoration progress to date.
http://s771.photobucket.com/albums/xx35 ... storation/
