After market rear sway bar
mostlytwowheeled
Post by mostlytwowheeled »
Anyone have a photo of a rear sway mounted on their spider? I picked one up new/never used, but no instructions where with it. I'll be able to figure it out, but a look at one mounted would help speed installation up. Thanks
mdrburchette
Re: After market rear sway bar
Post by mdrburchette »
Do you think someone at IAP might have a picture? I've got one but it's not installed.
mostlytwowheeled
I'll check with them, thanks.
TVST*R
Post by TVST*R »
http://www.Turbo124.com
has some pics of the rear sway bar on the yellow car.
mostlytwowheeled wrote:I'll check with them, thanks.
kensmith
Post by kensmith »
I have heard and I am no authority, that a 1" swap on the front sway bar is better than adding a rear sway bar.
mdrburchette
That's what I have on my 72 and it's a great handling car.
divace73
Post by divace73 »
There ia a company in Australia called K-Mac that does both front up grade and rear, pm me and I pass on a number if you that keen. Don't know what shipping will be like?
Cheers David
see my >>You tube channel<<
Razooli
Your car is a: 1982 Fiat Spider 2000
Post by Razooli »
@mostlytwowheeled
You've probably got the bar installed by now, but I thought I'd post these anyway for others. The instruction sheet that accompanied my Aadco rear bar was so light it was virtually unreadable and the diagram wasn't very clear. I cleaned them up and corrected some omissions, so here they are for whoever needs them. You can click on the link under the pictures to download a larger copy from Flickr. If I can find the pics I took during the install I'll put them in the same Flickr folder for reference.
One problem I had was the "base plate" and the "locking device" were so thin that they deformed when the nuts were tightened on the U-bolt allowing the unit to rotate on the axle. I added some steel shims and that helped but I've seen since that others have substituted muffler clamps for the stock parts to give a better grip on the axle.
Aadco Rear sway bar instructions R2 on Flickr
Aadco Rear sway bar instructions R1 on Flickr
Lynn Shuler
1982 Spider 2000
Remember, this hobby is supposed to be your therapy, not the reason you need therapy.
htchevyii
Patron 2022
Patron 2022
Post by htchevyii »
Cool, thanks. I have one with no instructions that I have yet to install.
Trey
kmead
Your car is a: 1969 850 SC 1970 124 SC 85 X19
Post by kmead »
I have always disliked this particular bar as it adds even more unsprung weight to a car that really doesn't need it.
Karl
1969 Fiat 850 Sports Coupe
1970 Fiat 124 Sports Coupe
1985 Bertone X1/9
donm
Your car is a: 1980 spider [carb]
Post by donm »
I ordered one a few weeks ago but I sent it back because after messing around with it for an hour under the car I could see that there was no way I could install it properly without moving the brake line that runs along the axle. It would have become a bigger project than I was prepared to do at that point.
1979 Spider
2001Saab SW
2004 Saab Aero
mostlytwowheeled
@Razooli
Thanks for the info on the sway bar. I haven't installed it yet as the snow has just finally melted away.I'm missing a couple of brackets but I'll be able to fab some up. Thanks for taking the time to post. Karl, as for the additional weight, that will be offset greatly by dropping the heavy bumper.
kmead
Post by kmead »
mostlytwowheeled wrote:@Razooli
:D It will be a reduction in sprung weight, the added weight to the axle will remain.
I am picking nits on this, obviously. Give us an update on its install (pics of the steps) and a review of how you like the change it brings to the handling. Clearly anecdotal (unless you have a repeating track day or autocross you can try it out on), but a good data point nonetheless.
Good luck on with the install.
Karl
1985 Bertone X1/9
azruss
Post by azruss »
found this is one of my books
dhagood
Post by dhagood »
wow, a torque tube encased driveshaft. that was only on the first two years, correct?
