I have everything off, the C-clip, the handle, the arm rest, but i can't seem to get the little black circle that the mirror control goes through!
How do i get it off?!
While we are on this topic, here is what I found inside my door when recently opened it up for the first time. (1980 FI Spider 2000) I am not sure if the covers over the openings were from Fiat or installed by a PO, but I can vouch for the fact that there is essentially zero rust on the doors. Original car color was obviously Bronze. There is some electrical tape and putty compound in there too, that seems to have done a pretty good job sealing out moisture. The door panel fibreboard is still in pretty good condition although a little out of shape. But I must caveat that I believe the PO (12 years they owned) did very little rainy day driving.
Yeah it is actually pretty clever, in a minimalistic sort of way. These white pieces are cardboard-type materials, and although it is not fully clear in the photo, they are notched about halfway down to hold them at an outward angle, so any water entering from the top would flow into the door frame area and away from the fibreboard panel backing. I plan to cover the back of the fibreboard with either a coating (acrylic or spar varnish or something) or plastic sheetgoods, when it all goes back together.
