I immediately thought it was one of the flex disk bolts that I may have not torqued correctly.
I stopped and went back to retrieve the bolt and looked up and down for the nut. Other than the driver there was no nut to be found in the vicinity.
However when I got home I found that all 6 donut bolts were in place and this new bolt was a complete mystery.
I looked for the usual suspects, alternator bolts, and whatever else I could see under the hood, all was well.
This one had some oil on it, but there are no leaks under the car.
It is the same size thread as the donut bolt, but it is about an inch shorter:
I only have two suspicions at the moment, either it was dropped by a mechanic sometime in the past and it just now decided to hop out onto the road, or it is a transmission bolt.
It was too hot under the car to look at the moment, but when it cools I'll be under there looking for it.
I'm open to suggestion!!!
Here's a look at the head of the bolt:
Otherwise everything is running just fine, but the Fiat just has to let you know who's boss!!
Neil
