I'm going to change the Auto trans filter and fluid in my spider soon. Went to autozone to pick up so fluid, my book calls for Dexron and 3 quarts for a drain & fill. The AZ guy gave me Castrol High Milage Fluid. Is this stuff correct?
http://www.castrol.com/castrol/sectiong ... Id=7033928
Automatic trans Fluid Type?
Re: Automatic trans Fluid Type?
It says in the description "GM 2005 MY and prior", so it should work, as Fiat used a GM automatic trans.
Thanks Csaba.
BTW, the stock rear muffler I got from you guys sounds good!
Anybody familair with the type of gasket ATP brand filter kits come with. Is gasket sealer required, should I use permatex? Thanks.
The general rule is to never use gasket sealer, unless the shop manual asks you to use it.Fiat88 wrote:Anybody familair with the type of gasket ATP brand filter kits come with. Is gasket sealer required, should I use permatex? Thanks.
If a sealing surface looks iffy, you may want to use aviation Permatex, it basically glues the gasket one. Will be a pain to remove later, tho.
Do these transmission pans have a magnet for particles? Didn't see one.
- 124JOE
i never was in one. but other tranys GM style that ive been in had one
yes you can add one
just be sure its a strong one
yes you can add one
