Anyway - thoughts
azruss wrote:making a custom curved bumper out of pipe is doable but takes a lot of work to make it not look like just that. need to look for a pipe shop with a hydraulic bender. if it is not a mandrel type the pipe will flatten on the tight corners. then you need to decide what you are going to do with the ends. flatten and weld, use plastic tube plugs, etc. now comes the hard part....finishing. prepping pipe for chrome is an arduous process getting the pipe flat and smooth. lots and lots of metal sanding.
how would u fasten them, meaning would u make it the same size as the original shock holes and fasten them as the bumpers where? i never looked ever to see how they are anyways,i have read there a bolt hole that can be used to fasten the t bars> am i rightkatsi wrote:I don't know. I'm thinking of a curved peice of metal that is chrome and can be bent. Just look at old bumpers. I guess is was thinking that if you looked at it from the side, it would kinda look like a "C" Don't know what I'm talking about but I have seen bumpers like this before.
