IMG_1028 by itzebtze, on Flickr
as per my shop manual they are not even listed parts
exploded view of the front brake caliper by itzebtze, on Flickr
did you forget a spacer??? ... my wheels are not original and they all had a spacer between the rotor and the wheel...forgetting one of those would make the wheel rub.... did it rub before the work just done?4uall wrote:sooooooo looks like the inner part of my right rim is rubbing the upper control arm?!? FML![]()
yes they are, they actually fit inside the rim without issue, no wobble yet it will only turn 3/4 around then sticks (when turned all the way to the left), only happens when wheel is turned all the way to the left81SPIDERMATT wrote:are those locating studs????? .... maybe the wheel is hitting them and not turning true.... if you spin the wheel does it have a wobble or does it spin true.... is it allways hitting the control arm or just at full turn of the steering wheel
let's see if I understand correctly what you are describing here: with the car jacked-up, and the wheel at full droop (spring extended) the wheel will spin. But when you turn the wheel to the left (I assume to full-lock?) you can only spin the wheel 3/4 of a turn, and then it sticks.4uall wrote: , no wobble yet it will only turn 3/4 around then sticks (when turned all the way to the left), only happens when wheel is turned all the way to the left
