Anyone ever thought of making one of these fit over dealing with rusted shock towers and cracked cross members?
http://www.fulltiltstreetrods.com/hub-to-hub-039web.jpg
Length of the A arms would be the only challenge and I arms sure you can custom order one of these to spec.
Retrofit Front Suspension
- 76124
- Your car is a: 76 124 Spider
Kraig
Everett, WA
76 Spider owned just shy 30 yrs and counting
69 Spider - Big truck ate it
74 Sedan special TC Auto..Died of cancer RIP
Everett, WA
Re: Retrofit Front Suspension
I thought about cutting off the whole works at the firewall and putting a front clip on the car. It's done in the hot rod scene all the time, maybe when I retire in 25 years?
Trey
Hey Trey, kind of like this?htchevyii wrote:I thought about cutting off the whole works at the firewall
It's still in my shop. trying to get motivated to finish the wiring and fuel delivery
Chris
holy moley!
WOW that is a ton of work!
I think I would make the front sheet metal one piece and have it all lift forward (like a Jag) for easy work on the mechanical etc.
For the suspension, the hotrod setup would work and give greater wheel tire combos as you could have the hubs drilled for any setup you want. Better brakes too if you have not gone bigger already.
If only we got paid to work on our cars!
Kraig
Everett, WA
Everett, WA
- v6spider
The closest after market would be a mustang II style of front-end. But the geometry needs to be maintained.
Out of necessity I had to modify and build new steering for my v6 powered spider. It is not an easy task. For a stock spider I would just rebuild what is there. If the body is rusted out in the front. It would be better to just replace it.... Any who my two bits...coming from someone who's been there...
Cheers!
Rob
Cheers!
Rob
http://www.v6spider.com
- Your car is a: 1975 Spider
im working on a front end for my other scorpion, which will use mustang II parts, im using wilwood spindles 2" drop, fabricated upper a arms, and a strut rod lower setup, and coil over shocks.
son has 78 spider
son has 78 spider
ive done exactly what was done above to a wrecked spider:
that was a lot of work
son has 78 spider
son has 78 spider
