BEEK wrote:
3 main reasons tie rod ends contact the exhaust are...
3. a different motor has been installed, a 2.0l in a 1800 car and the 1800 head pipe is used, it is shorter and guess what, it is not where it belongs.
joelbert2k wrote:Beek,
I suspect #3 is the issue. According to his signature it's a 69 with a 2ltr.
Steve,
Long time no see. New project?
Beek and Joel - I'm sure you're right, although I need to correct my sig. The engine is an 1800, I believe from a '76. Either way, it's not the original 1600, and so, of course, the exhaust is not original.
RRoller - the steering looks pretty well centered - at least to the eye of a non-expert.
This is a car that Mark Allison put together originally, and for the most part it's pretty well sorted. I have pushed the exhaust back and forth a little in the 2 years (or so) that I've had it - if I shift it toward the driver's side, it bangs against the differential at the back end. If I shift it toward the passenger's side, the tie rod end hits it. I'm afraid that my only recourse is some serious bending of the pipes - a project that I'm not real excited about. I like the "bang a dent in it" idea though. Maybe I'll just climb under there with a hammer in the morning (not really).
Joel - yep, it's been a while since I've been active on the forum. Mostly a combination of the car basically running well, and me not having any money to do anything to it. I picked it up from Mark a couple years ago to replace the '76 that got totaled. I did a couple projects right when I got it, but since then have just been driving it to work every day. I finally crawled under it this weekend to replace the transmission oil, and try to find the brake squeal. Calipers and pads all looked fine, but that's when I discovered the tie rod/exhaust thing. I may start showing up here a little more, as I have a couple projects that I want to do, and have cleared out some space in the garage. Mostly interior upgrades.
Cheers - and Merry Christmas!
-- se
