Went for a spirited drive yesterday and halfway through it no longer holds 4th gear.
If I try to hold it in gear it grinds.
my assumption is that means that it will have to be torn down or replaced.
Some vendors are selling new transmissions in addition to rebuilt ones.
They are quite a bit more expensive but I would consider it if they were really stronger/better.
Any opinions?
RIP - 4th Gear
- Your car is a: 1981 Spider
RIP - 4th Gear
'81 Spider
- Your car is a: 1969 fiat 124 spider
Re: RIP - 4th Gear
My Fiat Spider (1969) started doing the same thing quite a few years ago. I've never actually done anything about it as all the other gears work fine & there is no sign of any other problems. Don't think there is any way to diagnose the problem till the transmission is removed from the car.
- ga.spyder
Re: RIP - 4th Gear
Usually that is a bent or worn shift fork.This is often a result of people who drive while resting their right hand on the shifter.I drove mine w/o 4th gear for a couple years before saving enough to repair it.I got really good at 3rd to 5th shifting!
Craig Nelson
Fling It Around Turns !
- SLOSpider
- Your car is a: 1973 124 Spider 2.0FI
Re: RIP - 4th Gear
Welcome to the club. I got a couple of spares that Im waiting till I feel like changing the engine at the same time.
1975 124 Spider
1989 Chevy k5 Blazer
1967 GT Mustang Fastback
- Your car is a: 1985 Spider
Re: RIP - 4th Gear
So it seems my 1st to 2nd to 3rd to 5th pattern is pretty common.SLOSpider wrote:Welcome to the club. I got a couple of spares that Im waiting till I feel like changing the engine at the same time.
Don Avery
Dayton, OH/Sarasota,FL
1985 Pininfarina
2011 Eos
2012 Mercedes E550 Cabriolet
1985 Pininfarina
2011 Eos
- SLOSpider
Re: RIP - 4th Gear
4th is so overated, at least the is what my lazy side tells me
1975 124 Spider
- ga.spyder
Re: RIP - 4th Gear
If I hadn't run into Beeks ex partner at a car show I might still be w/o 4th gear.He offered to fix it,rather than do a complete rebuild.The rebuilt tranny I was going to buy ended up in Ron Luxmores car.Win-win for all!!
Craig Nelson
