Cowl Removal
davery
Your car is a: 1985 Spider
Cowl Removal
Post by davery »
In my prep for painting the car, I am getting ready to remove the cowl. Any secrets for an 85? Thanks.
Don Avery
Dayton, OH/Sarasota,FL
1985 Pininfarina
2011 Eos
2012 Mercedes E550 Cabriolet
TX82FIAT
Re: Cowl Removal
Post by TX82FIAT »
Pretty straighforward job. If you have some two inch wide painters tape it may be a good idea to put it in the seam between the cowl and the fender. This way you will avoid scratching paint taking it out and putting it in. Remove screws and rubber and pull forward.
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
4uall
Re: Cowl Removal
Post by 4uall »
azruss
Re: Cowl Removal
Post by azruss »
get yourself a couple of towels. one for each fender. when you pull it out, you slide the towel underneath each side. you have to lift the PS in order to unplug the wipers. Along with the tape you can save your paint.
