Aluminum coolant recovery tank
[img][IMG]http://i916.photobucket.com/albums/ad1/blairm222/Mobile%20Uploads/image_zps35fbe924.jpg[/img][/img]
Replaced original plastic tank which was cracking, with this polished aluminum one. $35. And used existing bracket. Takes up a lot less space.
Re: Aluminum coolant recovery tank
Nice knobs.
- hallgreghall
- Your car is a: 1977 Fiat
Where did you get that? Looks good.
I like Italian food and Italian convertibles
How do they vent the top?
Got it. Thanks.
Looks great! After you have used it for some time let us know if any concerns when coolant expands into new recovery tank and then is drawn back into cooling system once cool I have thought of doing something very similar but did not like the top connection to the tank.
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
There is a tube connected to the connector at the top of the tank. The tube goes down to the bottom of the tank. Should draw right back to the radiator.
- v6spider
That is exactly what I will be using...
Cheers!
Rob
Cheers!
Rob
http://www.v6spider.com
I don't think you'll find anything more compact. I know you'll be tight on space for your conversion.
- v6spider
Space is definitely a premium...but I have plenty of room for this catch can...plus it goes with the whole polished aluminum theme. I am doing...
Rob
Rob
- v6spider
Here's a link to the engine compartment shots of V6spider 1.0... note in the new version the hood scoop is omitted everything is concealed under the hood...surprisingly there is more room then even I remember...lol
http://www.fiatspider.com/f08/viewtopic ... &start=150
Rob
Rob
