Wire Wheels
Wire Wheels
Anyone know where one can buy spoke wire wheels for a 1981 Fiat Spider?
If not specificity avalable, are there other cars who have the same wheel bolt pattern,
OR
are there adapter plates available?
OR
Frog2Spider
'81 - 2000 Spider
Frog2Spider
'81 - 2000 Spider
- MrJD
- Your car is a: Looking to ask questions about a 79 2.0
Re: Wire Wheels
Itd be easy to do with adapters. I have seen a few wire wheels around, but they are not readily available.
Re: Wire Wheels
Here's a prior link on the subject:
http://www.fiatspider.com/f08/viewtopic ... ire+wheels
You'll find the search feature works pretty good for just about any subject. Not that there's a problem with a new discussion.
Re: Wire Wheels
The posts are 2 + years old! Am looking for some 'fresher' info. Thanks.Exit98 wrote:Here's a prior link on the subject:
Frog2Spider
'81 - 2000 Spider
Frog2Spider
'81 - 2000 Spider
Re: Wire Wheels
Very nice! Thanks.DanD wrote:http://daytonwirewheels.com/
Frog2Spider
'81 - 2000 Spider
Frog2Spider
'81 - 2000 Spider
Re: Wire Wheels
Just FYI wire wheels are super heavy, and a HUGE pain to get on/off the car.
- Your car is a: 1979 Spider
Re: Wire Wheels
And an even BIGGER pain to keep clean….!
- azruss
Re: Wire Wheels
As beautiful as wires are, they are an antiquated design....heavy, hard to keep round (tuning is a real art form), high maintenance. I suspect they move alot with side g's
Re: Wire Wheels
But they are pretty on the older cars.
M
M
1974 124 Spider
1964 500 D
2012 500 Sport
1948 Ford 8N tractor (restored (don't drink and ebay))
1964 500 D
2012 500 Sport
Re: Wire Wheels
I agree with everybody about real wire wheels they are heavy and can get out of line fairly easy. However I do like the look so I went with wire hub caps.
Gene
North Carolina
Gene
North Carolina
Gene
North Carolina
North Carolina
Re: Wire Wheels
Gene
I like the look. What kind of rims. Where did you get them and the caps
- johndemar
Re: Wire Wheels
The wire hubcap will fit on the original steel rim. They are still pretty heavy though even for caps.
I have a set that have been in the attic for the last 35 years. Most likely a little dusty by now.
76 Fiat 124 Spider
One owner since July 20, 1976
Amadio Motor, Jeannette, PA
Re: Wire Wheels
My wire cap came off of a corvair. I found them in a junkyard. Took them apart and cleaned them up one spoke at a time. They actually aren't heavy. They are not steel but polished aluminum. I found some fiat centera on ebay and used auto twould way molding tape to adhere them to the caps. I know most people are going with mags but I just like the look of the hubs.
Gene
North Carolina
North Carolina
Re: Wire Wheels
I have a single one of the FIAT wire hub caps NOS if anyone is ever trying to complete a set.
