Caliper Spring Clips Install
KRegester
Post by KRegester »
Ok, Which one is correct?
A - Spring resting on the back of the caliper applying pressure outward.
B - Spring between the angled shim and caliper bracket.
A - looks like the way it was designed to work with the spring resting on the angled cut on back of the caliper but car had them installed like B.
Re: Caliper Spring Clips Install
A is correct, I've seen them assembled like B also, but that binds the caliper and won't let it slide. Also, the sliding pieces should be lubricated with a caliper grease. Bendix ceramlub is the best
KRegester
Post by KRegester »
So Cal Mark wrote:A is correct, I've seen them assembled like B also, but that binds the caliper and won't let it slide. Also, the sliding pieces should be lubricated with a caliper grease. Bendix ceramlub is the best
Thanx Mark!
Yeah, It didn't make sense to mill out the back for no good reason.
This is just a temp assy to check fit.
I will pull the calipers and bead blast them before hi temp painting them too.
The brackets silica blasted nicely and have VHT paint on them.
