this is a good used bearing race, of course, the whole bearing had to be replaced
this is a 5th reverse layshaft extension, a piece of the 5th gear syncro engagement area was broken off and was run through this. the next picture will show missing teeth on the 5th gear
this is 5th gear
i also replaced both shift hubs and all 4 brass syncros and the 1-4 shift forks.
