Are these sensor being use in other 75" 124 spiders i'm in california but don't need smog cause it tops out at 1975 and lowwer
Anyways so what are the 2 bottom sensor used for and there's also one on top of the manifold if not need can i leave them be and not have to worry?
Also what is this 2 way brass tube there to the right there use for or go to or can it be simply plugged?
Thanks Much Again Guys!
The 2 sensors in photo #1
Center Sensor in photo.
2 way Brass "T" off the the top right side?
