Excessive heat on the passenger side
70spider
Your car is a: 1970 Fiat spider
Post by 70spider »
Hello everyone,
I just got back from a long ride with the wife and the heat on her side was a bit much. I do not have any carpet at the moment, just finished painting and putting in the old style sound deadening (rubber-like) stuff. I noticed when I was under the car that the exhaust runs pretty close to the trans and close to the floor. This proximity of the exhaust next to the tranny can't be good for it. I was thinking of wrapping it with a heat shield, something like this.
http://thermotec.shptron.com/p/pipe-shield-2-motorcycle
Is this a good idea? Also what is a good thermo insulation to put down inside before I install the carpet?
Thanks Pesto
2002 Mazda Protege5
2013 Buddy 170i
spidernut
Re: Excessive heat on the passenger side
Post by spidernut »
All it will take is a little insulation under your carpet. Reflectix from Home Depot works quite well. Almost any foil-faced insulation or radiant barrier will also do the job. Foil faced products like Dynamat and Fatmat also will do the trick.
Re the exhaust, I'm personally not a fan of wrapping the exhaust system with anything.
John G.
1977 Spider (Sold 2017)
1979 Spider (Sold 2015)
1980 Spider (Sold in 2013)
1981 Spider (Sold in 1985)
we use Dynamat
wetminkey
Post by wetminkey »
Insulate the floor and do not wrap any part of the exhaust,...that only causes metal corrosion due to trapped condensation.
My Spider came from the factory with the standard asphalt-backed carpet underlayment and a 1/4" thick foam pad to insulate against the heat of the catalytic converter under the carpet. You'll need to substitute accordingly as stated in the previous posts.
Todd.
1988 Mazda RX-7
1979 Fiat Spider 2000
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
Post by RRoller123 »
EZ Cool is very thin and works well, not expensive either. I doubled it up over the Cat and there are no heat issues whatsoever.
njoconnor
Your car is a: 1972 124 Spider
Post by njoconnor »
+1 on Pete's recc of EZ Cool. Here's how my 72 turned out:
I added a layer to the kickpanels behind the map pockets, and covered the whole rear seat area as well. Needed 2 rolls, have enough left over for one replacement side if I ever need it. Laid it down with spray adhesive directly over the metal floors (scraped all the old stuff off). I also copied Pete's idea of 2 thin layers of hobby foam over the floor surfaces. Like your 70, my 72 does not have a cat, so a single layer of insulation with the thin foam on top has eliminated heat (and a lot of noise).
Something not always mentioned: new weatherstripping on all the openings does a wonder at reducing panel and general noise. Well worth the cost and effort, IMO.
Neil
Neil O'Connor
Madison, WI
72 FIAT 124 Spider
ex-71 FIAT 124 Coupe
fredguaz
Your car is a: 1977 Fiat Spider
Post by fredguaz »
Are your heat shields installed? Should be 2 metal shields riveted to the underside between exhaust and floor.
Fred
Lake Norman, NC
1977 Fiat Spider (current project)
1977 Triumph Bonneville 750 (previous project)
1971 Honda CT-70 K0
1972 Honda CT-70 K1
1990 GMC S-15 Jimmy (Daily driver)
70spider
Post by 70spider »
Thanks for the info.
As far as heat shields riveted to the underside, the car is a 1970 and has no catalytic so there are no heat sheilds.
I like the EZ-cool idea do you think one roll (http://www.ebay.com/itm/4-x-50-EZ-Cool- ... 70&vxp=mtr) would be enough? , I dread the thought of pulling the seats again but I think it is a must do at this point.
2002 Mazda Protege5
2013 Buddy 170i
4uall
Post by 4uall »
njoconnor
Post by njoconnor »
70spider wrote:Thanks for the info.
If you concentrate on the floor pans and the console, (and really tuck the pattern pieces/carpet sections close), I believe a single roll will get you through. You can also piece it, and cover the seams with aluminum tape (you'll need that anyway...a roll will do). Well worth doing, IMO, even with the seat removal PITA..... :|
4uall's thread was very helpful when I did mine; Pete's thread as well.
Neil
Neil O'Connor
Madison, WI
72 FIAT 124 Spider
fredguaz
Post by fredguaz »
I have a 77 with no catalytic converter but my heat shields are n place. One is well forward of where the cc would be.
Hope his helps.
Fred
Lake Norman, NC
1971 Honda CT-70 K0
1972 Honda CT-70 K1
bradartigue
Post by bradartigue »
The transmission gets very hot. A lack of insulating material and the interior boot will bring a lot of heat from the transmission into the car. It is far worse when the top is up / vent windows open. Why the passenger side is worse than the driver's side is the proximity of the exhaust, air passing through the engine bay and under the car is simply heated on that side. Cars with the original pan (even the early cars had them originally) don't experience this quite as much from what I've noticed.
Exit98
Post by Exit98 »
Not sure why pulling your seats is such a chore although getting the screw head bolts out can be a hassle. I replaced mine with these allen head bolt I got at my local Tru-Value store. Now I can use a ratchet to get them in and out. Big improvement.
Sorry for the size. For some reason Photobucket wouldn't let me resize the picture.
Also when pulling the seats its important that the seats go back and forth the full length of the rails to allow maximum access to the bolts. The rails sometimes lock up before full range. You should be able to easily see and reach the bolts front & back. Once the seats are out clean and lube the rails.
Good luck.
4uall
Post by 4uall »
Exit98
Post by Exit98 »
You know Jay, I'll bet I got that idea from you and that post.
Works great, thanks.
