Then I hit the rear shocks. I think I'm having some serious problems? Looks like most folks on here just remove the lower shock bolt. Mine looks like it settled down into the springs and there is no way to remove it. I have taken a few pictures but I don't know if anyone can see a problem or has ran across this before.
Is there an answer to get the shocks off. They are both like this.
It seems like the bolt should be above the blue bottom but the bolt will hit the spring dish before it can come out.
I can move the spring around but there is no room to get the bolt to slide out of the shock bottom.
I have learned soooo much from fellow members, I hoping there is someone with a trick, or is my shock support in serious trouble and sunk out of sight.
