OK, stupidist question yet. I have had it with the dual points system on my 78'. Tried the International Auto fix to make it a single set. Did not work worth a hill of beans. Would not start no matter how many times I followed their instructions.
So reading the forum as usual, I see a lot of talk about changing to electronic breakersless system.
It seems to always be spelled "Petronics"? Only thing I could find on internet was a "Pertronics" system. Autowarehouse.com had Pertronics universal conversion for my 78'.
So did I find a Chinese knockoff? Or is there actually a Petronics brand and a "Pertronics" brand. It looked exactly like the set Autoricambi sells. They ship for $73.00 total a "Pertronics" Universal Conversion to electronic points .
For "Petronics" I found Facebook pages, Norwegian robotics, etc.
Petronics-Pertronics
- Texsardo
- Your car is a: 1978 Fiat Spider Convertible 1800
- Contact:
- divace73
Re: Petronics-Pertronics
if you don't want to spend the cash get a 2nd hand fiat electronic ignition system, is your dizzy cam mounted?
Cheers David
see my >>You tube channel<<
Those go for a lot more money!divace73 wrote:if you don't want to spend the cash get a 2nd hand fiat electronic ignition system, is your dizzy cam mounted?
- 81SPIDERMATT
pertronics actually pertronix
- johndemar
Short of opting for Marks system, petronix with their flame thrower coil was one of the best things I did for my 76.
Simple to put on as well.
76 Fiat 124 Spider
One owner since July 20, 1976
Amadio Motor, Jeannette, PA
- spidernut
Mine has a crane fireball breakerless ignition. It works great. The timing must be set at 10BTC at idle instead of the factory 0 BTC if you go that route. The instructions don't tell you that.
John G.
1977 Spider (Sold 2017)
1979 Spider (Sold 2015)
1980 Spider (Sold in 2013)
1981 Spider (Sold in 1985)
- Texsardo
- Contact:
Re: Petronics-Pertronics. Resolved
Thanks 81spidermatt, Pertronix it is then. I was just afraid I had ordered some cheap knock off that most likely not work or burn out in a month or even more worse, burn me up in a fiery motor death. Thanks everyone. Just wanted to know what the real item is used by forum members..
PS my dizzy is fine, seals OK, just points are so outta there. Also, any mention of wiring colors in my car are only about 20% of most people's note.
Texsardo
Texsardo
Or, upgrade by buying from the person on here parting out his 81
- Your car is a: 1976 124
In the last ~10 years I head of 4 Crane units failing.
That is true regardless of what ignition system is used.
