Valve adjustment
new O2 sensor
oil vapor recycler clean/hose replaced
clean and gap plugs
vacuum advance replaced
all fluids, and filters
timing belt
strobe timing
idle at 950 rpm
Thermo time checked out OK
I realized that back when I got the car, in '98, I loosened the air flow meter spring...d'oh!, so after failing the smog test, I've bought a replacement. I had been smelling what I thought was just old gas fumes, but now think is a rich condition. I also found my cold start injector to drip a little instead of spraying at cold start, but NOT drip while running. I rigged up a battery and "shocked" it several times and now have a nice spray, and again, no drip. I bought a new temp sensor but it reads very closely in resistance to my original, though I'll install it with the "new" AFM. I also did not drive a lot before the test, though long enough for a few fan cycles.Anyway, here's the results.
I'm just hoping it's not dripping or bad injectors, as I'm near my limit with the car right now.
