Leaking fuel tank
Leaking fuel tank
Went to take my '71 124 out of storage and discovered a slow leak in the fuel tank...what are my options?
- riverdadd
- Your car is a: 1975 Fiat Spider 1977 Alfa Spider
Re: Leaking fuel tank
where is the leak's source? maybe you can get lucky and just tighten a clamp. if it is a pin hole then u can get some "gas tank repair putty" and stick a bubble gum sized wad on it.......... if more serious, like a leak @ the seam, then replacement tanks are fairly cheap. or go used..... hope that helps
- Your car is a: 1983 mira
In my experience, the epoxy tank patches have been a temporary fix. They will eventually leak.
I finally removed the tank and took it to a radiator shop. They boiled it out and soldered the leaky places.
AR has new tanks with internal baffels and great prices.
Thanks for all the info...turns out it was just the hose from the filler pipe to the tank...whew!
