Don't you just hate it when you think that you have everything sorted out on car so you button everything up, give it a wash inside and out then go for a drive just to find out that you have a new issue? Well...just happened to me today. When making a right turn, I'm getting a sound as if the driveshaft is hitting the tunnel...thump, thump, thump as I go around the corner. Well...back under the car again. I suspected it had bad bushings on the upper and lower trailing arms, and panhard rod based upon a previous set of creaks and pops.
That would be a LOT of shifting of the differential. EEK! I'm thinking it is because I had removed the rear anti sway bar and now the play is evident. I hope not, but it will be what it will be.
Dang - thought I had it ready to go
- spidernut
John G.
1977 Spider (Sold 2017)
1979 Spider (Sold 2015)
1980 Spider (Sold in 2013)
1981 Spider (Sold in 1985)
Re: Dang - thought I had it ready to go
If the inner seat belt bolts are too long (into the center tunnel) they can come very close to the driveshaft, and a little
shifting during a turn can make it rub.
When my car was new, it made a similar sound. The muffler was near the driveshaft, and it was hitting. I just bent the lip of the muffler and that fixed it.
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
