OK, so this is strange. I was driving the car down the road andhti a few bumps. The car lights dimmed, the radio went off. The car began to stall. I hit another bump and everything came back on.
I parked in my sisters drive way and turned the car off. Came back out after 2 hours, nothing. I could not start it and the radio/head lights woudl not come on.
We used my Tahoe to tow it home with a strap. After hitting a few more bumps, with the keys in the on position, suddenly, the radio came back on and I started it right up.
Where is the best place to look for the issue. Now, its in the garage, and again, no power.
1980 Spider 2000 Loose connection??? Bad Ground???
Well,
Something worked, they only trouble is, I'm note sure which it was. I also had to replace the battery. Once I had gone in and made sure all the connections were good both inside the car and at the starter, i decided to jump it. She started right up after sitting for 6 months. I have a new battery now and it seems to do the trick. Although, the right blinker does not work any more.... Must be a short somewhere else. Hey, at least she is up and running.
Thanks!
Thanks!
