A couple of forum members have asked how I mounted the Procar seats? Others have done it differently and you can find there posts with a search. I tried to keep it simple, make adapter brackets and use the stock Fiat sliders. The problem with the Procar spacing is it is just a little off. So little that the bolts for mounting an adapter to the seats interferes with the mounting bolts for the slides. It would be better if they were further off! Anyway,what I did was offset the front mount for the seat from the front mount for the slides and put spacers between the adapter brackets and the slides to get a flush mount. Aluminum 2" wide and 1/4 " thick. Should be more than enough shear and tensile strength in the event of an accident.
Picture of drivers seat mount 1:
Side view showing bolt head interference, offset and spacer:
Offset at front:
Other side:
Set of adapters and spacers for the other side:
My sketch for the brackets:
I could also have offset toward the front instead but I found the travel forward to be plenty and they go further back than I can use at 5' 11" . Plus you need to do it this way to be able to clear enough to get the bolts holding the sliders to the car rails in and tight! Hope this helps anyone contemplating a set of these.
Oh, and these are still for sale in the for sale section!
