Brake Device Near MC
PatTroy
Post by PatTroy »
Anybody know what this is? Residual pressure valve?
I'm really struggling with soft brakes on my race car and this is the only part left that I have not changed.
micbrody
Your car is a: 1981 fiat 2000
Re: Brake Device Near MC
Post by micbrody »
It has to be some sort of check valve. I found this online:
"A residual valve acts like a one-way or check valve to maintain brake system pressure to eliminate the problems of a spongy pedal. This 2 PSI residual valve is installed inline between the master cylinder and disc brake calipers to keep 2 PSI of residual pressure at the caliper after the brake pedal is released."
My car does not have it; though I wonder how much it improves feel of braking......very intriguing.....
aj81spider
Post by aj81spider »
That looks like the switch that triggers your brake light if one of your brake circuits fail. The front and back circuits run through it and there is a switch between them. If one loses pressure the switch flips from the center position and lights your brake light indicating a brake system failure. There should be an electrical connector on the top or bottom that has the wires that complete the circuit.
A.J.
2006 Corvette
