Hi all,
At one time my trunk had a spring loaded bar mechanism that could be turned out to hold the trunk open. It was bent and never worked correctly, During my restoration I put on a different truck lid that didn't have the keep-it-open bar.
Can someone post a pictures of a working mechanism so I can see if I can acquire/fabricate and reinstall the device? Right now I keep a broomstick handle in the trunk and use it to keep the trunk open when needed.
Thanks.
Picture needed: Trunk keep-open bar install
- nelsonj
Simi Valley, California
Spider 1800
Romans 10:9
- kilrwail
Re: Picture needed: Trunk keep-open bar install
Here you go.
Peter Brownhill
1977 Porsche 911S - track car
2022 Ram 4 x 4 - hauler
Peter Brownhill
- nelsonj
Thank you very much! This gives me just what I needed.
Thanks again.
Thanks again.
Spider 1800
Romans 10:9
- Your car is a: 1969 fiat 124 spider
Was able to buy a used prop & spring a couple years ago.
- Your car is a: 124AS 1969 Fiat Spider
Nelson, here is a photograph of my mechanism. You should be able to get the spring and rod from someone like Mrfiat.com. Be careful when opening your trunk as it can hit the part behind the top if opened too far. Gregory
