Rust above rear spring mount
Anyone ever have rust at the top of the rear spring mounts, where it joins the inner fender well?
1978 Fiat Spider 1800
2010 F350 6.4 Lariat 4x4
2012 Gulfstream 35qbh
2006 Smart Fortwo Convertible
2000 VW Beetle
1990 Saab 900 Turbo
1992 Saab 900 Turbo Convertible
2015 Jeep Wrangler Willys Unlimited
2014 Bayliner 175
2000 VW Beetle
1990 Saab 900 Turbo
2014 Bayliner 175
- Your car is a: Fiat 1982
Re: Rust above rear spring mount
I had passenger side at seatbelt:
Pretty much exactly like that. Is it repairable or not worth the trouble?
2000 VW Beetle
1990 Saab 900 Turbo
2014 Bayliner 175
2000 VW Beetle
1990 Saab 900 Turbo
2014 Bayliner 175
Completely repairable... I've got pics somewhere... but I took mine down to bare body. I had rust at pass side rear spring mount/seatbelt mnt. Also had rust at rear fender wells. I cut and ground everything out down to good metal. (note, while I was grinding out at intersection of of fender well a and floor pan, I was not holding tightly and grinder wheel pinched, bounced off body and smashed into my face- I was was very lucky as it hit me just above my teeth and at edge of my nose. Now have a gnarly scar there... inner repairs I used 12 gauge sheet and got fender well pieces from autoricambi. I used a spot welder and mig....
Got a little flux core mig welder. The spot welder is my next tool investment. Glad to hear it's fixable. I've done the front strut towers. I was hoping that this wasn't going to be the end.
2000 VW Beetle
1990 Saab 900 Turbo
2014 Bayliner 175
2000 VW Beetle
1990 Saab 900 Turbo
2014 Bayliner 175
Found some pics:
Nice. Doesn't look too bad. Like the spot welder. Is that how you were joining two panels to fix the rear quarter panel?
2000 VW Beetle
1990 Saab 900 Turbo
2014 Bayliner 175
2000 VW Beetle
1990 Saab 900 Turbo
2014 Bayliner 175
Yes. I used the spot welder and offset bender to fit all parts and then I ran continuos bead along joints with mig.
